LD_PATHS
Till Straumann strauman at slac.stanford.edu
Wed Apr 20 03:28:53 UTC 2005
Ralf Corsepius wrote:
>On Tue, 2005-04-19 at 17:25 -0700, Till Straumann wrote:
>>Ralf.
>>I found this comment
>>2002-11-13	Ralf Corsepius <corsepiu at faw.uni-ulm.de>
>>	* compilers/gcc-target-default.cfg: Remove obsolete reference to
>>	src/libxil/Makefile.
>>	Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc
>>	-spec).
>>in the cvslog for c/src/make/compilers/gcc-target-default.cfg
>I don't recall the details of this change anymore.
>>How is that supposed to work? It broke applications that set LD_PATHS
>>in their makefiles
>Here you say it: "application ... makefiles"
>gcc-target-default.cfg is part of OAR's brain-dead application makefile
>template system and meanwhile (for several years) is not used by the
>source tree anymore. As I have said dozens of times before, if I was to
>decide about it, the application makefile template system was abandoned
>years ago.
>gcc-target-default.cfg suffers from the same flaws as all other
>application makefiles: RTEMS has no chance to know what application want
>nor which variables they want to use, and therefore can't care about it.
>I.e. if something inside of the makefile template system doesn't meet
>your applications' demands, change/edit it to your demands.
>So I guess, all the changelog entry above is referring to is
>streamlining gcc-target-default.cfg to what the RTEMS makefiles use
>themselves.
>> [README qualifies LD_PATHS as a makefile variable].
>Which README? Such a statement is wrong and would qualify as a
>documentation bug.
The <rtems_install_top>/make/README. The problem is that there _are_
applications
[I have a few] out there that use the makefile system and they rely on
what that
system has done in the past, so please don't break it. Call it a
documentation bug
but since that documentation bug has been out there for a long time it's
dangerous
to assume that nobody uses the documented features...
Till
>Ralf
