netdemo
g_YaneV g_yanev at bulpost.com
Mon Aug 1 16:33:57 UTC 2005
hello,
As you can see from  my tethereal output I use 24742 as destination port. I
also try 24743. Same problem.
On Monday 01 August 2005 19:09, Joel Sherrill <joel at OARcorp.com> wrote:
> g_YaneV wrote:
> > Hhello,
> > I have some problems with running netdemo. The bord is mcf5282 based and
> > I use uC5282 port.
> > The problem is that I can't telnet to the board. All other commands are
> > working perfect(s, u  & t ).
> It doesn't accept connections on standard ports.  Try
> telnet board_ip PORT
> where PORT is 24742 .. 24742+NUMBER_ECHO_TASKS
> > On startup rtems prints:
> > fs1: Ethernet address: 00:80:7f:22:61:77
> > Destination     Gateway/Mask/Hw    Flags     Refs     Use Expire
> > Interface default         10.10.10.4         UGS         0        0
> > 0 fs1 10.10.10.0      255.255.255.0      U           0        0      1
> > fs1 10.10.10.4                         UHL         1        0      1 fs1
> > Create socket.
> > Create socket.
> > Bind socket.
> > Bind socket.
> > Listen.
> > Listen.
> > Accept.
> > Accept.
> > So there is no problem opening the sockets. When I try to telnet the
> > following packages are passing via the network:
> > #tethereal -i eth0
> > Capturing on eth0
> >   0.000000   10.10.10.4 -> 10.10.10.11  TCP 43689 > 24742 [SYN] Seq=0
> > Ack=0 Win=5840 Len=0 MSS=1460 TSV=164222258 TSER=0 WS=0
> >   0.000452  10.10.10.11 -> 10.10.10.4   TCP 24742 > 43689 [RST, ACK]
> > Seq=0 Ack=0 Win=0 Len=0
> > Any suggestions what did I do wrong, or from where to start the
> > debugging.
> > regards,
> > George
