RTEMS on AVR?
Evgeny Belyanco esp1 at kbkcc.ru
Fri Aug 5 10:11:22 UTC 2005
Wednesday, August 3, 2005, 9:53:04 PM, you wrote:
JSjOc> I added code for 16-bit IDs as a step in this direction.  If you
JSjOc> are going small, there is no reason for extremely large number of
JSjOc> objects or multiprocessor node information in the ID.
JSjOc> Ralf has focused on making sure the code is 16 bit clean.  When you
JSjOc> use an int, you need to make sure it is OK with only 16 bit ints.
IMHO, 16bit will by useful even in ARM platform with low RAM
resources.
JSjOc> I am concerned that in the smallest RAM configurations, the notion
JSjOc> of each task having its own dedicated stack might be unsupportable.
JSjOc> 8K RAM definitely doesn't make you want to give each task a portion
JSjOc> of that.  There are alternate schemes to be looked at when memory
JSjOc> is that right.
JSjOc> So TinyRTEMS is a concept and a goal.  We do not have feature
JSjOc> requirements defined for what the "tiniest RTEMS" will be.  Any
JSjOc> comments and thoughts would be appreciated.
May be sometimes we will found "configuration manager": we will choose
options, and receive answers about resources requirements. And each
customer will personally decide, what is more important: additional
RAM (and separate space for each task, stability) or price.
Evgeny Belyanco
Chief Designer KB KCC
* E-mail: ea at kbkcc.ru
* Phone (cel.): +7 901 510 9046
* Fax: +7 095 926 9787
* Web: http://www.kbkcc.ru
* Post address:
   KB KCC, suite 209,
   ul. Butirsky Val, bld. 68
   Moscow, 127055, Russia
