[PATCH] pc386 BSP: initialization of PCI bus
Keith Robertson kjrobert at alumni.uwaterloo.ca
Fri Aug 19 09:37:11 UTC 2005
Karel Gardas wrote:
> IIRC Gregory Melke recommended to initializa PCI bus in bsp_startup
> function of pc386 BSP early this year. Attach patch tries to implement
> this. It is tested on two x86 systems one with 3C905C-TX and other with
> Intel's Ethernet NICs.
> Since till now, initialization of PCI bus was done in appropriate device
> driver on pc386 BSP, I hope it is right to place its initialization
> after all needed initializations of IRQ and exceptions management code.
Karel,
Do you happen to know if this patch causes any problems on pc386 bsps
without a PCI bus?  Personally, I'm particularly interested in qemu with
the -isa (aka no pci) option.   However, there's likely(?) other setups
without PCI.
Cheers,
Keith
