[PATCH] if_fxp: do not initialize PCI bus itself
Jennifer Averett jennifer.averett at oarcorp.com
Fri Aug 19 11:28:08 UTC 2005
> Karel Gardas wrote:
>> Hello,
>> if_fxp NIC driver worked well on pc386 BSP, since it initializes PCI bus
>> itself. Experts here pointed out that this is wrong way early this year
>> and I've finally removed this initialization from the driver and tested
>> that it still works with the pc386 BSP with previous PCI bus init patch
>> applied. Hopefuly this is also right for other supported platforms.
> This steps into more of a grey area to me.  It looks like
> pci_initialize() is called from bspstart.c for every BSP that calls
> it.  So that assumption is safe.
> However, it also looks like other drivers in libchip/network
> call pci_initialize().  So if it is correct to remove
> the call to pci_initialize() from the if_fxp driver, it must
> also be correct to do from the other drivers.
> I need to either not apply the patch or remove the call
> to pci_initialize from the other drivers.  If we do the latter,
> we are assuming that the BSP will take care of that for
> device drivers.
> Comments?
> --joel
IMO, it seems more appropriate to let the BSP take care of it.  Otherwise,
when multiple libchip drivers are used pci_initialize could be called
multiple times.
jennifer
>> Cheers,
>> Karel
>> Karel Gardas                  kgardas at objectsecurity.com
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
>> Index: c/src/ChangeLog
>> RCS file: /usr1/CVS/rtems/c/src/ChangeLog,v
>> retrieving revision 1.259
>> diff -u -r1.259 ChangeLog
>> --- c/src/ChangeLog	15 Aug 2005 13:54:15 -0000	1.259
>> +++ c/src/ChangeLog	18 Aug 2005 18:51:16 -0000
>> @@ -1,3 +1,7 @@
>> +2005-08-18  Karel Gardas  <kgardas at objectsecurity.com>
>> +	* libchip/network/if_fxp.c: Remove initialization of PCI bus.
>>  2005-08-15	Ralf Corsepius <ralf.corsepius at rtems.org>
>>  	* optman/Makefile.am: Add preinstall.am.
>> Index: c/src/libchip/network/if_fxp.c
>> RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_fxp.c,v
>> retrieving revision 1.16
>> diff -u -r1.16 if_fxp.c
>> --- c/src/libchip/network/if_fxp.c	18 Jul 2005 15:42:24 -0000	1.16
>> +++ c/src/libchip/network/if_fxp.c	18 Aug 2005 18:51:37 -0000
>> @@ -447,16 +447,6 @@
>>  	s = splimp();
>> -	 * init PCI Bios interface...
>> -	i = pci_initialize();
>> -	DBGLVL_PRINTK(2,"fxp_attach: pcib_init returned %d\n",i);
>> -	if (i != PCIB_ERR_SUCCESS) {
>> -	  device_printf(dev, "could not initialize pci bios interface\n");
>> -	  return 0;
>>  	 * find device on pci bus
>>      { int j; int pbus, pdev, pfun;
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>     Support Available             (256) 722-9985
