Developent Environments for RTEMS
Aaron J. Grier aaron at frye.com
Tue Aug 30 18:00:26 UTC 2005
On Fri, Aug 26, 2005 at 04:28:40PM +0200, Karel Gardas wrote:
> Yes, if you play a bit with ``External Tools'' I'm sure you can
> convience Eclipse CDT to compile RTEMS apps. IMHO it's not that
> difficult, just matter of providing right command-line args to the
> right dialog boxes.
I've done this with a co-workers' Eclipse install.  it was originally
set up for the cypress CY7C67300 USB host adapter, but eclipse calls out
to make, so by changing the Makefile I had it cross-compiling using the
RTEMS tools in a few minutes.
my "IDE" consists of vim, gdb, and minicom...
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
