netdemo
    g_YaneV
    g_yanev at bulpost.com
    Mon Aug  1 17:07:09 UTC 2005
ping work just fine. I can ping and I recieve the replys.
On Monday 01 August 2005 19:59, Joel Sherrill <joel at OARcorp.com> wrote:
> YaneV wrote:
> > hello,
> > As you can see from  my tethereal output I use 24742 as destination port.
> > I also try 24743. Same problem.
> I can't read tethereal that well.  When you ping the board, is it
> received and do you get a reply?
> --joel
> > On Monday 01 August 2005 19:09, Joel Sherrill <joel at OARcorp.com> wrote:
> >>g_YaneV wrote:
> >>>Hhello,
> >>>I have some problems with running netdemo. The bord is mcf5282 based and
> >>>I use uC5282 port.
> >>>The problem is that I can't telnet to the board. All other commands are
> >>>working perfect(s, u  & t ).
> >>It doesn't accept connections on standard ports.  Try
> >>telnet board_ip PORT
> >>where PORT is 24742 .. 24742+NUMBER_ECHO_TASKS
> >>>On startup rtems prints:
> >>>fs1: Ethernet address: 00:80:7f:22:61:77
> >>>Destination     Gateway/Mask/Hw    Flags     Refs     Use Expire
> >>>Interface default         10.10.10.4         UGS         0        0
> >>>0 fs1 10.10.10.0      255.255.255.0      U           0        0      1
> >>>fs1 10.10.10.4                         UHL         1        0      1 fs1
> >>>Create socket.
> >>>Create socket.
> >>>Bind socket.
> >>>Bind socket.
> >>>Listen.
> >>>Listen.
> >>>Accept.
> >>>Accept.
> >>>So there is no problem opening the sockets. When I try to telnet the
> >>>following packages are passing via the network:
> >>>#tethereal -i eth0
> >>>Capturing on eth0
> >>>  0.000000   10.10.10.4 -> 10.10.10.11  TCP 43689 > 24742 [SYN] Seq=0
> >>>Ack=0 Win=5840 Len=0 MSS=1460 TSV=164222258 TSER=0 WS=0
> >>>  0.000452  10.10.10.11 -> 10.10.10.4   TCP 24742 > 43689 [RST, ACK]
> >>>Seq=0 Ack=0 Win=0 Len=0
> >>>Any suggestions what did I do wrong, or from where to start the
> >>>debugging.
> >>>regards,
> >>>George
