still problem with new/old interrupts on PowerPC and CVS ?
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Fri Aug  5 15:15:10 UTC 2005
On Fri, 2005-08-05 at 08:20 -0500, Joel Sherrill  wrote:
> Ralf Corsepius wrote:
> >>>On Thu, 2005-08-04 at 12:48 -0500, Joel Sherrill  wrote:
> >>>>Ralf.. libcpu/irq.h is in the staging area of the build directory but
> >>>>not at the install point:
> >>>I could reproduce the problem and believe to have fixed it in CVS-trunk.
> >>>Ralf
> >>Looks good, came much further. Hello_World get compiled, but :
> >>make[1]: Entering directory `/SHARED1/RTEMS/examples/filerdback'
> >>test -d o-optimize || mkdir o-optimize
> >>powerpc-rtems-gcc --pipe
> >>-B/SHARED1/RTEMS/rtemsdocs-4.6.99/powerpc-rtems/ss555/lib/ -specs
> >>bsp_specs -qrtems   -g -Wall  -O4 -fno-keep-inline-functions -g
> >>-mcpu=505 -Dmpc555 -Dss555     -c   -o o-optimize/test.o test.c
> >>test.c:12:20: error: memory.h: No such file or directory
> >>make[1]: *** [o-optimize/test.o] Error 1
> >>make[1]: Leaving directory `/SHARED1/RTEMS/examples/filerdback'
> >>make: *** [all] Error 1
> > OK, we are facing several problems at once.
> > 1. memory.h is an BSD'ism (Read it is non-portable), portable code
> > should "#include <string.h>", instead.
> > I.e. this code should be updated.
> > 2. RTEMS memory.h is part of libnetworking, and is only being installed
> > when building RTEMS with networking enabled.
> > This is a long withstanding defect in RTEMS, I am struggling with for
> > quite a while (The problem is far more general than just memory.h).
For the moment, I have changed RTEMS-CVS in such a way that memory.h is
always being installed.
But I am considering to remove it, because of 1.)
Ralf
