Recommended tool versions for Cygwin host?
Per Dalgas Jakobsen
pdjpub at knaldgas.dk
Sun Aug 14 15:17:53 UTC 2005
Hmmm, I take that I have asked for the impossible...
Ok, then how if I relax the host-requirement to Linux?
That is: Linux/RTEMS cross-compiler with remote debugging (ethernet),
supporting C and Ada95 for an i386 target (and host).
Any combination of tool-versions that can be recommended?
~Per
Per Dalgas Jakobsen wrote:
>>> I want to have a Cygwin/RTEMS cross-compiler with remote debugging
>>> (ethernet), supporting C and Ada95 for an i386 target.
>>> Any recommendations of which versions/patches to use, to get a good
>>> and reliable toolchain for this combination?
>> You should be able to download pre-compliled tool binaries from
>> <http://rtems.org/>.
> I tried the download-helper, but Cygwin-host with Ada-binaries wasn't
> available for any RTEMS-version in the list.
> Obviously I must have looked the wrong place. Can you guide me to the
> correct place please?
> ~Per
