Making FAT delete work
    Camilo Alejandro Arboleda
    camilo.arboleda at spymac.com
    Tue Aug 16 22:17:55 UTC 2005
Thanks,
The patch worked fine, it just genarated some warnings about "hunk #x
succeed at line...".
Joel Sherrill <joel at OARcorp.com> escribió:
> Camilo Alejandro Arboleda wrote:
>> Hi,
>> I'm updating my application from RTEMS 4.5 to RTEMS 4.6.2. After some
>> work I made my flash driver work in the new version. But now I find
>> that 'unlink()' doesn't work anymore.
>> As far as I can see, the problem is in the msdos_eval_path()
>> function. Before deleting the file, RTEMS try to check permissions
>> for ".." directory, but msdos_eval_path fails with 'ENOTDIR'. I want
>> to copy the IMFS functionality, but I'm not able to figure how to
>> open the parent node of a file on msdosfs.
>> Maybe I'm missing something. Is there someone who is using FAT
>> support and is able to delete files?
> Is this PR744?  If so, there is an attached patch.  It was made versus
> CVS but I don't see it applied to the CVS head.
> If you can make it work and submit it as a patch against 4.6 and the CVS
> head, it would be greatly appreciated.  This needs to be fixed.
> I don't know what the issue was regarding this patch.  It is not
> uncommon for me to wait until there is a patch against 4.6 and CVS head
> if the issue applies to both.
>> Thanks in advance,
