RTEMS4.7 PPC clock(was Re: IRQ latency, mvme5500 v1.3 )
Kate Feng
feng1 at bnl.gov
Wed Aug 17 12:51:57 UTC 2005
I agree with what Till Straumann suggested for the IRQ handling
and prioritization of the RTEMS-MVME5500 BSP. Thanks again.
However, for the PPC shared file
c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
in RTEMS4.7CVS, can one please replace the following:
void clockIsr(void *unused)
int decr;
* The driver has seen another tick.
do {
asm volatile ("mfdec %0; add %0, %0, %1; mtdec
%0":"=&r"(decr):"r"(Clock_Decrementer_value));
Clock_driver_ticks += 1;
* Real Time Clock counter/timer is set to automatically reload.
rtems_clock_tick();
} while ( decr < 0 );
with the same implementation as RTEMS4.6.0 shown below
until a better algorithm proposed ?
PPC_Set_decrementer( Clock_Decrementer_value );
rtems_clock_tick();
The reason ?
First, I do not think it's a good idea to disable interrupts
around the "asm volatile" code either.
Second, does the new code fix a bug I am not aware of in 4.6.0 ?
Perhaps, I did'nt understand the code right or miss some point.
However, I stole the broken code to my version of RTEMS4.6.x
and ran the IRQ latency test. It actually did'nt improve the worst
and the average case. I doubt the 4.7 compiler will make a
difference. Besides, the rtems_clock_get() reported that it
took 500.2 second to run the test, which is supposed to
be 500 seconds. EPICS uses rtems_clock_get(), I think. Anyway,
the processor is so fast that I think the original code I got
from the RTEMS4.6 sufficient to be accurate.
Thanks,
Kate
