Almost done
    Erwin Rol
    mailinglists at erwinrol.com
    Thu Aug 18 17:22:27 UTC 2005
Hey Phil,
The version of GDB that Leon (correct me if i am wrong) is using can be
found on http://www.erwinrol.de/index.php?opensource/bdm.php
I also made a patch for GDB 6.3 but that didn't work as expected, but i
didn't have time to look into why. It seems that some bigger changes
happened between GCB 6.1 and GDB 6.3.
Also since i don't have access to MPC860 hardware anymore the
development has pretty much halted (from my side). But sources and
patches are available for everybody that wants to fix/extend it.
- Erwin
On Thu, 2005-08-18 at 10:03 -0700, Phil Torre wrote:
> Leon,
> Does your gdb-6.1.1 have bdm-4-gdb (also known as mpcbdm) applied?  If so,
> I'd
> be grateful for your source code.  I don't even know for sure what is
> involved
> in moving mpcbdm over to gdb-6.x, but it didn't move from 4.x to 5.x without
> some massaging, so I assumed it wouldn't just be a drop-in.
> -Phil
