IRQ latency (was Re: RTEMS-MVME5500 BSP v1.3 available)
Till Straumann
strauman at slac.stanford.edu
Thu Aug 18 20:25:46 UTC 2005
Peter Dufault wrote:
> On Aug 10, 2005, at 8:36 PM, Kate Feng wrote:
>> Peter Dufault wrote :
>>> Me? No, I *never* disable interrupts! (well, almost never).
>> Yes, it's better to limit it to the minimum.
>>> But seriously, no I didn't disable interrupts. I'm a firm believer in
>>> lock-free systems, which to my thinking means trying to push the
>>> locks down to the hardware level.
>> I am not sure if you will get an accurate timestamp in you test as
>> you mention that you use system clock, especially under the heavy
>> load. Anyway, Till should make a conclusion about its pedigree.
>> He is the one who made the enhancement in RTEMS4.7 PPC
>> shared port.
> Kate asked me off-list if I'd disabled interrupts in my timings, and
> this is how I responded. I'd have been less tongue-in-cheek on-list,
> but it's OK with me for anyone forward my emails unless I say not to.
> I use the 64-bit Power-PC time counter, not the system clock, so the
> timings should be very accurate.
> In an earlier posting I said that if something resets that time
> counter I'm in trouble, but I'm 99.99% sure that the time counter is
> left alone.
AFAIK, the PPC TB is never (re)-set / changed. I also use it for timing
purposes.
-- Till
> Till will tell.
> Peter
