[PATCH] pc386 BSP: initialization of PCI bus
Karel Gardas
kgardas at objectsecurity.com
Fri Aug 19 13:46:49 UTC 2005
Keith Robertson wrote:
> Karel Gardas wrote:
> > IIRC Gregory Melke recommended to initializa PCI bus in
> bsp_startup
> > function of pc386 BSP early this year. Attach patch tries to
> implement
> > this. It is tested on two x86 systems one with 3C905C-TX and
> other with
> > Intel's Ethernet NICs.
> > Since till now, initialization of PCI bus was done in appropriate
> device
> > driver on pc386 BSP, I hope it is right to place its
> initialization
> > after all needed initializations of IRQ and exceptions management
> code.
> Karel,
> Do you happen to know if this patch causes any problems on pc386
> bsps
> without a PCI bus? Personally, I'm particularly interested in qemu
> with
> the -isa (aka no pci) option. However, there's likely(?) other
> setups
> without PCI.
Keith,
true! I have not tested the code on non-PCI system due to missing hardware
and completely forgotten the option to use qemu -isa for testing. Anyway,
I would expect code to only print warning message about missing PCI BIOS
and otherwise not harm at all, thought I will not be able to test it on
qemu in the near future. If you will do testing yourself, please keep us
posted!
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
