problem with download rtems src release
    Jeff Mayes
    Jeff.Mayes at OARcorp.com
    Fri Aug 19 14:07:25 UTC 2005
Apparently, this has been a problem for a while, yet I didn't know about
it until this morning.  Please let
us (joel and I) know about administrative issues.  We may not be able to
fix them all, but can't if we are
unaware.
While investigating this issue, I experienced the same problems
described by Ian.  Joel and I were both
accessing the ftp site from a remote facility external to the OAR
firewall.  We could login but ls, dir, and
pwd commands would not work.  Then, suddenly and "magically" it started
working.  No changes were
made to the system.  At the moment, it is working.  Please give it a try
and let me know what happens.
Thanks
Jeff
Ian Caddy wrote:
> Hi Sam,
> There seems to be a problem with the ftp server, in that it seems to
> have quite high security setup for someone outside the domain.  It
> will let you download files if you know the exact name via the ftp
> site, but it won't respond to a dir or ls command.  It will change
> directories though.  At least this is what we seem to have found.
> Another way is to use the http access method.
> http://www.rtems.com/ftp/pub/rtems/4.6.2/
> Should get you where you want to go.  It looks just like an ftp site,
> but accessed through the web server.
> I hope this helps,
> Ian Caddy
> Bsderss wrote:
>> Hi,
>> I tried to download rtems src from the following url,
>> ftp://ftp.rtems.com/pub/rtems/4.6.2
>> But the download request waited for more than 10
>> minutes, then timed out. I think there may be a
>> problem with ftp request..
>> Can I download the tar file of the source release?
>> Thanks
>> Sam
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam?  Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com
