4.6.99.2 csb337 BSPbuilding Error
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Dec 1 15:14:32 UTC 2005
Jay Monkman wrote:
> Juergen Zeller wrote:
>>Sorry for the off topic question,
>>i'd like to have a csb337 as starting point for a new projekt, but AFAIK
>>cogent doesn't sell this board anymore. has anybody of you a tip where
>>to get a csb337?
> Cogent has a new board that's similar. It's the CSB637. You can build RTEMS for
> the CSB337 and run it on the newer board. Or, if you only need  a few boards,
> you should check with Cogent. They may have some  left.
Jay.. can you update the Wiki to make sure the 637 is referenced.
Should the BSP be altered in anyway to reflect support for the 637?
For example, a BSP alias added?
--joel
