problems of "target rtems" and "attach" in remote debugging with gdb
Yan Luo
yan_luo at uml.edu
Thu Dec 1 15:00:23 UTC 2005
Hello,
I have problems with i386-rtems-gdb when remote debugging over RPC.
one problem is the "target rtems" command, gdb connected with remote
server but complained with the Magic number error. The other problem
is "attach 1" afterwards, gdb said "Dont know how to attach, try
'help target'". Let me describe my setup and steps.
Our experiment setup is as follows: concurrent technologies VP101
PentiumIII VME board, suse linux as development host. VME boards
boots up through BOOTP. RTEMS 4.6.5, netdemo application.
First, i386-rtems-gdb compiled with the patches (downloaded together
with RTEMS 4.6.5) did not recognize "setrpcmode" or "setdaemontype".
After google around, I followed the instructions at http://
www.rtems.org/ml/rtems-users/2001/june/msg00065.html, and added
"'remote-rte.o rtems.o thread_rte.o rtems/rteRemDebXdr.o' to the gdb/
Makefile COMMON_OBJS. Then after fixing a number of compilation
errors, the i386-rtems-gdb generated does recognize setrpcmode and
setdaemontype commands.
Second, I setup the netdemo application, and it worked well. When
telnet to the remote target, the strings typed were echoed back
correctly. I could also ping the remote target. Then I added
"rtems_rdbg_initialize()" in init.c to bring up rdbg server. That
worked as I could see RDBG was up running on console.
Third, in i386-rtems-gdb, I did setrpcmode and setdaemontype. After I
issued "target rtems remote-name", gdb showed the remote target is
connected. However it complained about the magic number. I then tried
"attach 1", gdb said Dont know how to attach, try 'help target'".
I noticed that, the target_ops structure in remote-rte.c is different
from the structure described in "RTEMS Remote Debugger Server
Specifications". I guess this might be the reason of magic number error.
Any suggestions how to fix the problems?
Thanks.
Yan Luo
