Fwd: configuring memory size
Ed Sutter esutter at lucent.com
Tue Dec 6 18:44:13 UTC 2005
Can't disagree there!
Ed
Till Straumann wrote:
> Sorry for the urge I feel to repeat myself.
> IMO, the whole approach of creating multiple linker scripts and binaries,
> one for each memory / board configuration is bad.
> A single instance should perform a run-time check and configure the
> workspace and heap according to the amount of memory detected.
> T.
> Ed Sutter wrote:
>> Peter,
>> If you're looking for alternatives, then I also have a homegrown tool
>> that I use for this.  Very trivial, but does what I want, essentially
>> replacing a few sed/awk script with something that keeps everything to
>> one
>> simple command line.
>> The purpose is slightly different than Thomas's, so you'll have several
>> options!  The purpose is to maintain the address information for the
>> linker
>> file in my makefile as a variable.  Then the variable can be included in
>> CFLAGS if needed, along with being used as input to a template that
>> creates
>> the final linker command file.
>> Anyway, the tool (called vsub) is included in the MicroMonitor source
>> distribution
>> at http://www.microcross.com/html/micromonitor.html, or I can just send
>> you the source for that alone.
>> Lemme know if you want it.
>> Ed
>> Thomas Doerfler wrote:
>>> Hi,
>>> just as an additional idea: Some years ago I used the C preprocessor
>>> to generate linker command files from a template. The benefit was,
>>> that I could have ONE header file defining address/size information
>>> for the C compiler and for the linker.
>>> Maybe this would also be convenient for Peter?
>>> wkr,
>>> Thomas.
>>> D. Peter Siddons wrote:
>>>> Hi Till,
>>>> The bsp is very similar to the uC5282. _M68k_Ramsize is copied from
>>>> the linker value (_Ramsize) in bsp_start() (part of bspstart.c). I
>>>> could easily check for the two possibilities here. Is that early
>>>> enough?
>>>> Pete.
>>>>> Eric Norum wrote:
>>>>>>> Looks like what I suggested won't work.   The linker complains
>>>>>>> if  the expressions in the  ORIGIN/LENGTH contain symbols even if
>>>>>>> those  symbols have been defined before the assignment.
>>>>>>> I guess that you'll need to have two separate linkcmds files and
>>>>>>> use something like
>>>>>>>     -Wl,-TlinkcmdsFor4MFlash
>>>>>>> or
>>>>>>>     -Wl,-TlinkcmdsFor16MFlash
>>>>> A much better solution would be enhancing the BSP so it does
>>>>> auto-detection. This has to be performed early enough,though.
>>>>> If an early detection is too cumbersome, then you can limit
>>>>> the initial size to a minimum, let's say 4M and increase the
>>>>> size later. In order to make the additional ram available to
>>>>> RTEMS (i.e., after the malloc heap/libc have been initialized)
>>>>> you have to implement a trivial 'sbrk()'. The only constraint
>>>>> is that the 'late ram'-portion of the heap to be added by sbrk()
>>>>> must be contiguous to the initial heap.
>>>>> You can look at powerpc/shared/bspstart which uses the
>>>>> two-staged heap approach for different reasons.
>>>>> HTH
>>>>> T.
>>>>>>>> Eric Norum wrote:
>>>>>>>>>> You need to pass the --defsym option to the linker.
>>>>>>>>>> On the compile line, add something like
>>>>>>>>>>     -Wl,--defsym,_RamSize=0x10000000
>>>>>>>>>> On Dec 2, 2005, at 10:50 PM, D. Peter Siddons wrote:
>>>>>>>>>>> I have two boards which are identical except for the amounts
>>>>>>>>>>> of  flash and RAM. The linkcmds file has definitions for
>>>>>>>>>>> these   parameters like:
>>>>>>>>>>> _RamSize = DEFINED(_RamSize) ? _RamSize : 0x7f0000;
>>>>>>>>>>> so my question is, can I invoke a definition somewhere in
>>>>>>>>>>> the   application make process to override the one in
>>>>>>>>>>> linkcmds? If  so,  how and/or where?
>>>>>>>>>>> Pete.
>>>>>>> Eric Norum <norume at aps.anl.gov>
>>>>>>> Advanced Photon Source
>>>>>>> Argonne National Laboratory
>>>>>>> (630) 252-4793
