RTEMS with ARM LPC2138
    Sam
    samwun at telpacific.com.au
    Wed Dec 14 11:29:26 UTC 2005
Jay Monkman wrote:
>Sam wrote:
>>Can anyone please tell me whether RTEMS compatible with this device?
>RTEMS should run on it, but as others pointed out the  LPC2138 has limited RAM
>which will severely limit the capabilities. You should probably forget about
>trying to do standard TCP/IP with it since you've got so little memory. The
>RTEMS stack is unhappl unless it's got at least 256K available for buffers.
>>In this webpage, I also found that their Developer Kit is very expensive
>>- 395 EUR.
>>Is there other recommendation of embedded hardware device I can use for
>>RTEMS development? I basically need 2 ethernet ports on the device.
>Cogent (http://www.cogcomp.com) makes a board based on the AMD Au1550 - MIPS
Hi, what difference between this with WRAP? Wrap is only around 120USD.
Sam
>core - which has 2 ethernet ports. Their development board is around $600 I
>think. However, it has much more memory. RTEMS runs on an earlier model of the
>board, so it should work on the newer one - some minor changes may be needed.
