AW: RAMDISK in FAT format
Wilfried Busalski w.busalski at lancier-monitoring.de
Thu Dec 15 09:44:26 UTC 2005
Thanks for your response..
Wilfried Busalski
-----Ursprüngliche Nachricht-----
Von: Pavel Pisa [mailto:ppisa4lists at pikron.com]
Gesendet: Donnerstag, 15. Dezember 2005 01:09
An: joel.sherrill at oarcorp.com
Cc: rtems-users at rtems.com; Wilfried Busalski
Betreff: Re: RAMDISK in FAT format
On Thursday 15 December 2005 00:30, Joel Sherrill <joel at OARcorp.com> wrote:
> Pavel.. could you add this to the Wiki?
> And if you don't mind, I will try to grab your example tomorrow and
> move it to at least contrib.  It is probably more useful in the
> examples I buidl all the time but one step at a time.
> --joel
Hello Joel,
I would be only pleased, if the code and work can be reused
and helps others.
If you think about taking whole MMC/SD code, then wait for
a while. I have to add DMA driven read/write. I have plan to do that before
morning, but I am stuck on some dispute about Linux code port.
It would help, if you can add example to the Wiki yourself now, I am really
out of time this month and would not probably find time for that.
Best wishes
               Pavel
> Pavel Pisa wrote:
> > On Wednesday 14 December 2005 10:59, Wilfried Busalski wrote:
> >>Hi
> >>I need a little help to use a FAT RAMDISK.
> >>Is there an example to see how it is to use?
> >>Regards
> >>W.Busalski
> > Hello Wilfried,
> > I have time only for glimpse answer. But I have teaching MMC/SD to
> > work with FAT last week, so some code fragments could help.
> > I have found next lines in some former RTEMS post.
> > I have not author name on hand to credit him so excuse me. This is
> > slightly updated, to correct function names etc.
> > Steps to mount and create file:
> > 1. msdos_format("/dev/ramdisk0", NULL);
> > 2. ide_part_table_initialize("/dev/ramdisk0");
> > 3. binary fstab
> >   fstab_t fs_table[] = {
> >       "/dev/ramdisk0", "/mnt/ramdisk0",
> >       &msdos_ops, RTEMS_FILESYSTEM_READ_WRITE,
> >       FSMOUNT_MNT_OK | FSMOUNT_MNTPNT_CRTERR | FSMOUNT_MNT_FAILED,
> >       0
> > 4. rtems_fsmount( fs_table,
> >                   sizeof(fs_table)/sizeof(fs_table[0]),
> >                   NULL);
> > 5. creat("/mnt/ramdisk0/file1", S_IREAD | S_IWRITE);
> > The examples with already working MMC/SD driver can be taken from my
> > homepage
> > http://cmp.felk.cvut.cz/~pisa/rtems/rtems-mx1-mmcsd-051212.tar.gz
> > Look at file mmcsd_rtems.c for examples.
> > Best wishes
> >             Pavel Pisa
