edb7312 and SkyeEye followup - SUCCESS
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Dec 15 19:54:37 UTC 2005
Jay Monkman wrote:
> Joel Sherrill <joel at OARcorp.com> wrote:
>>The BSP has a network driver.  It is for the on-CPU NIC right?
> No, it's an external CS8900.
>>If so, then it should just be a matter of figuring out how to setup the
>>simulator to host part.
>>FWIW there are also cs8900a and rtl8019 simulator chunks in the source.
> In that case, it shouldn't be too hard to get it working. I didn't know what
> devices it supported.
In the source file device/net/dev_net_cs8900a.c, I see this:
static struct device_default_value cs8900a_net_def[] = {
         /* name         base        size   interrupt array */
         {"at91", 0xfffa0000, 0x20, {16, 0, 0, 0}},
         {"s3c2410x", 0x19000300, 0x20, {9, 0, 0, 0}},
         {NULL},
I guess the name field has to match the mach field in the configuration.
It seems to end up dependent on the table in
arch/arm/common/arm_arch_interface.c.  I don't really see how the NIC
gets hooked in yet.
--joel
