GMS/GPS with RTEMS (former Re: GPRS with RTEMS)?
Sam samwun at telpacific.com.au
Fri Dec 16 07:03:37 UTC 2005
> Sam wrote:
>> I just found out I made a serious typo and mistake in typing the name, I
>> really meant GSM/GPS rather.
> Ah yes, this is different.
>> I would like to know what kind of SBC (like
>> handheld small board) and software I can use for building a GSM/GPS
>> application based on RTEMS.
> It is difficult to comment as you do not detail the requirements of the
> application.
>> I found that  Intel® XScale™ uSBC from
>> http://www.cogcomp.com/ is a very efficient and powerful hardware can be
>> relied on. But Microcross does not offer development tools base on
>> RTEMS.
>> What is the effort of developing GSM/GPS application based on RTEMS and
>> port it over to a reliable and efficient platform like Intel® XScale™
>> uSBC?
>> Any other alternativies?
> Did you check the Wiki:
>   http://www.rtems.org/wiki/index.php/BoardSupportPackageInformation
> If you look under the ARM section and you will see references to Cogent
> boards. I just added links to the Wiki to Cogent's web site.
Not sure how much (significantly) different compared to Intel Xscale uBSC.
And its price is not in the list of that pdf file. I also found that this
2 boards does not have built-in LCD. Does it support wireless PCMCIA card
that can be used to interface with GPS/GSM signals? or any other way
built-in device I can use to interface with GPS/GSM?
Thanks
Sam
> Regards
> Chris
