Two sequential calls to _thread_Enable_dispatch() ?!
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Sat Dec 17 19:40:19 UTC 2005
Alex wrote:
> Hi all,
> Please look to the mqueueopen.c file.
> Why there are 2 sequential calls to _thread_Enable_dispatch() function in the mq_open() POSIX.4 primitive?
> Are they necessary? Does one call to _thread_Enable_dispatch() is not enough?
> If there is configured extensions, each call to _thread_Enable_dispatch() will execute the exensions. Thus we are delaying the execution time of the mq_open() primitive, right?
> Sorry, I am confused...
> Can you help me?
> Many thanks,
Unusual case and probably needs a better comment.  But it is needed.
There is a _Thread_Disable_dispatch() at line 57 and at line 112, the
call to _POSIX_Message_queue_Get() again implicitly increments it.
I suppose the first call could be a _Thread_Unnest_dispatch to indicate
that it was intentional.  Even better might be comments indicating where
the nest level goes to 2 and back down to 1.
