RTEMS 4.6.5 biuld failed in FreeBSD 6.0
Sam samwun at telpacific.com.au
Sat Dec 24 11:13:47 UTC 2005
Ralf Corsepius wrote:
>>>On Sun, 2005-12-18 at 18:27 +1100, Sam wrote:
>>>>Hi,
>>>>I tried to build RTEMS 4.6.5 under FreeBSD 6.0, but it failed at the
>>>>"gmake" stage with the following error:
>>Here is teh attached script file captured
>>during the compilation...
>OK, I realize what's going on.
>ramdisk.c depends on libc providing EBADRQC. Apparently BSD doesn't do
>so, while most other *nix's do so, and rtems-4.6.x/cpukit/configure
>fails to handle this situation.
>Try rtems-cvs/HEAD (4.7). There, libblock is disabled for all *nix/posix
>targets, which should allow you to compile it.
>Ralf
Hi, I have checked out 4.7, how to compile the source? I don't find a
"configure" file in the rtems/ directory.
Thanks
Sam
