patch to nfs addon to correct problem with latest stdint.h
Thomas Fors
tom at fors.net
Tue Dec 27 22:58:32 UTC 2005
FYI,
I've found the following patch necessary to get the nfs addon to
compile. The patch resolves an incompatibility with the latest
changes made to rtems/cpukit/include/rtems/stdint.h
Platform: cygwin
Target: uC5282
GCC: 4.0.2
rtems: cvs checkout -D 2005-12-26
addons: cvs checkout -D 2005-12-26
Thomas Fors <tfors at aps.anl.gov>
Advanced Photon Source
Argonne National Lab
--- orig/rtems-addon-packages/rtemsNfs/src/nfs.c 2005-09-02
10:40:51.000000000 -0500
+++ src/rtems-addon-packages/rtemsNfs/src/nfs.c 2005-12-27
13:31:16.757500000 -0600
@@ -2427,8 +2427,8 @@ struct rtems_libio_tt {
static int nfs_file_open(
rtems_libio_t *iop,
const char *pathname,
- unsigned32 flag,
- unsigned32 mode
+ rtems_unsigned32 flag,
+ rtems_unsigned32 mode
iop->file_info = 0;
@@ -2443,8 +2443,8 @@ static int nfs_file_open(
static int nfs_dir_open(
rtems_libio_t *iop,
- unsigned32 flag,
- unsigned32 mode
NfsNode node = iop->pathinfo.node_access;
@@ -2499,7 +2499,7 @@ static int nfs_dir_close(
static int nfs_file_read(
rtems_libio_t *iop,
void *buffer,
- unsigned32 count
+ rtems_unsigned32 count
readres rr;
@@ -2544,7 +2544,7 @@ Nfs nfs = node->nfs;
static int nfs_dir_read(
rtems_libio_t *iop,
void *buffer,
- unsigned32 count
DirInfo di = iop->file_info;
@@ -2603,7 +2603,7 @@ RpcUdpServer server = ((Nfs)iop->pathinf
static int nfs_file_write(
rtems_libio_t *iop,
const void *buffer,
- unsigned32 count
@@ -2649,7 +2649,7 @@ int e;
#ifdef DECLARE_BODY
static int nfs_file_ioctl(
rtems_libio_t *iop,
- unsigned32 command,
+ rtems_unsigned32 command,
void *buffer
)DECLARE_BODY
#else
