Building the toolchain for powerpc-rtems4.7 on i686-pc-cygwin fails
Avy Strominger
astrominger at yahoo.com
Sat Dec 31 13:31:03 UTC 2005
Hello everybody,
I'm trying to build the toolchain for powerpc on Cygwin. The target
is to have an RTEMS for MPC555, with Ada. I'm following the building
instructions on Wiki for RTEMSAda, and the build fails when trying to
compile the C cross compiler (First build of non-multilib C only stage),
with the following error:
config.status: creating Makefile
config.status: creating testsuite/Makefile
config.status: creating config.h
config.status: executing default commands
make[1]: Entering directory
`/cygdrive/d/c-dev/tools/gcc-4.0.1/build-i686-pc-cygwin/libiberty'
if [ x"" != x ] && [ ! -d pic ]; then \
mkdir pic; \
else true; fi
touch stamp-picdir
make[1]: *** No rule to make target `../include/ansidecl.h', needed
by `regex.o'. Stop.
make[1]: Leaving directory
make: *** [all-build-libiberty] Error 2
This is when using gcc-4.0.1. Config.status file is included, so you
can see the configure command.
With gcc-4.0.2, result is similar:
Any help will be appreciated.
Avy Strominger
URL: <http://lists.rtems.org/pipermail/users/attachments/20051231/a4d53ea4/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20051231/a4d53ea4/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20051231/a4d53ea4/attachment-0001.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20051231/a4d53ea4/attachment-0002.ksh>
