user extensions private data in TCB question
Till Straumann
strauman at slac.stanford.edu
Tue Dec 6 01:42:19 UTC 2005
Chris Johns wrote:
> Till Straumann wrote:
>> How does a user extension determine it's slot/pointer
>> in the TCB extension area -- is 'rtems_index(extension_id)'
>> the standard method?
> Yes as far as I know. You need the extension's id to obtain the index.
>> If so:
>> How can an 'initial' user extension (i.e., one that was
>> created during rtems_initialize_executive_early())
>> determine the slot number it owns in the 'extensions'
>> array of the TCB?
> Could you be a little more specific ?
Besides being created (rtems_extension_create()),
extensions can also be added to the configuration table
(CONFIGURE_INITIAL_EXTENSIONS & friends). In this
case, I don't see how these extensions get an index and
name.
T.
> An extension should have a name and so you should be able to obtain
> the id and therefore the index.
>> From scanning through the sources, it seems that
>> initial extensions don't even have a slot for private
>> data in the TCB -- is that true? [if so: bummer!].
> What source/extensions are you referring to ?
> Chris
