Fwd: configuring memory size
Till Straumann
strauman at slac.stanford.edu
Tue Dec 6 18:54:12 UTC 2005
D. Peter Siddons wrote:
> Hi Till,
> The bsp is very similar to the uC5282. _M68k_Ramsize is copied from
> the linker value (_Ramsize) in bsp_start() (part of bspstart.c). I
> could easily check for the two possibilities here. Is that early enough?
Yes.
The value is used to configure the heap in bsp_pretasking_hook().
The workspace is initialized in rtems_initialize_executive_early(), somewhat
prior to calling the pretasking hook.
Tuning the heap and workspace related parameters from bsp_start() should
be OK.
Reading the amount of memory from a config register or jumper or probing
for the
top of memory in bsp_start() should be preferred to hard-coding in the
linker script.
HTH
T.
> Pete.
> Till Straumann wrote:
>> Eric Norum wrote:
>>>> Looks like what I suggested won't work. The linker complains if
>>>> the expressions in the ORIGIN/LENGTH contain symbols even if
>>>> those symbols have been defined before the assignment.
>>>> I guess that you'll need to have two separate linkcmds files and
>>>> use something like
>>>> -Wl,-TlinkcmdsFor4MFlash
>>>> or
>>>> -Wl,-TlinkcmdsFor16MFlash
>> A much better solution would be enhancing the BSP so it does
>> auto-detection. This has to be performed early enough,though.
>> If an early detection is too cumbersome, then you can limit
>> the initial size to a minimum, let's say 4M and increase the
>> size later. In order to make the additional ram available to
>> RTEMS (i.e., after the malloc heap/libc have been initialized)
>> you have to implement a trivial 'sbrk()'. The only constraint
>> is that the 'late ram'-portion of the heap to be added by sbrk()
>> must be contiguous to the initial heap.
>> You can look at powerpc/shared/bspstart which uses the
>> two-staged heap approach for different reasons.
>> HTH
>> T.
>>>>> Eric Norum wrote:
>>>>>>> You need to pass the --defsym option to the linker.
>>>>>>> On the compile line, add something like
>>>>>>> -Wl,--defsym,_RamSize=0x10000000
>>>>>>> On Dec 2, 2005, at 10:50 PM, D. Peter Siddons wrote:
>>>>>>>> I have two boards which are identical except for the amounts
>>>>>>>> of flash and RAM. The linkcmds file has definitions for
>>>>>>>> these parameters like:
>>>>>>>> _RamSize = DEFINED(_RamSize) ? _RamSize : 0x7f0000;
>>>>>>>> so my question is, can I invoke a definition somewhere in the
>>>>>>>> application make process to override the one in linkcmds? If
>>>>>>>> so, how and/or where?
>>>>>>>> Pete.
>>>> Eric Norum <norume at aps.anl.gov>
>>>> Advanced Photon Source
>>>> Argonne National Laboratory
>>>> (630) 252-4793
