Event not timing out with a wait of 1 tick (and sometimes 2)
Steven Johnson
sjohnson at sakuraindustries.com
Fri Dec 16 02:02:02 UTC 2005
Hi Joel,
> Since you are hacking on the source anyway, you could add a variable
> which is set to note that you are at the flash and clear it when
> interrupts are redisabled. Then when the 0 at the head of the delta
> chain occurs there is a bread crumb. Several places could be marked
> this way.
> When you get the fault, check _ISR_Nest_level and check it.
We did the following test:
The ISR_Flash macro was modified to set "_ISR_In_Flash" on entry and
clear it on exit.
We added the following code to the watchdog tickle:
if (_ISR_Nest_level > 1)
_ISR_Nest_Count++;
if (prev_in_flash)
if (!the_watchdog->delta_interval)
the_watchdog->delta_interval = 1;
prev_in_flash = 0;
if (_ISR_In_Flash)
prev_in_flash = 1;
The results are these:
1. A breakpoint on the the _ISR_Nest_Count++ never triggered.
2. A breakpoint on "prev_in_flash = 1" triggered every so often.
3. A breakpoint on "the_watchdog->delta_interval = 1;" also triggered
So this seems to prove that what is happening is that interrupts are
being enabled after the delta_interval is being set to zero, but before
it is added to the watchdog chain. An ISR occurs (but not a nested one)
that removes all the entries from the head of the watchdog chain. When
the ISR returns, the zero calculated delta is added, but instead of
being after the entries in the chain it is calculated on it is added at
the head because all of the entries it was calculated relative to have
been removed. Which causes the next watchdog tickle (following the one
that occured during the flash) to remove the head with 0 in it,
decrement to 2^32-1, and exhibit our fault.
I dont use simulators, but i imagine you could force this behaviour by
careful control of the simulator to exhibit these characteristics for
verification.
To also answer Jennifer,
>On most of the PowerPC boards using new interrupt processing, interrupts
>are turned back on in C_dispatch_irq_handler allowing nested interrupts.
>If this is occuring in your bsp, you may want to stub out the sections
>that do this and see if the problem goes away.
We dont actually use either the old or new PowerPC interrupt processing
in RTEMS, i did my own interrupt processing (loosely based on the old
powerpc interrupt processing) for my target years ago, and have stuck
with it cause its works fine for me and ive tuned it to my liking for
the mpc860 irq's. Which was why i was pretty sure we shouldnt have
nested IRQ's. The above test indicates that we arent getting nested
IRQ's in this instance, as _ISR_Nest_Count is never incremented.
Hope that helps.
Steven Johnson
