Strange bug on EP9302-based custom board
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Dec 16 13:21:25 UTC 2005
Ian Caddy wrote:
> Jay Monkman wrote:
> <snip>
>> That's a real waste of CPU time. You'll end up spending a significant
>> amount of
>> time in interrupt processing.
>> 10ms is the default tick rate for RTEMS, and a pretty standard tick
>> rate for
>> other OSes. Until recently, that was the rate for Linux on x86.
> We use a 1ms tick since our systems (Power Utilities) SCADA like 1ms
> resolution on all digital inputs and a lot of our timeouts are based on
> small millsecond times.  This is on a 90MHz Coldfire processor with no
> dramas.
Most if not all of the systems I know that OAR has consulted on use
either a 1 millisecond or 500 microsecond tick.  FOr the 500 microsecond
tick, the CPU has to be pretty fast and the application had to have good
reason.
> regards,
> Ian Caddy
