Debugging RTEMS APP
Keith Robertson kjrobert at alumni.uwaterloo.ca
Tue Dec 27 11:19:32 UTC 2005
sunpeng at mail.ustc.edu.cn wrote:
> Hi,all
>    When I try "make debug" in the example "Hello_World_C",here are the error
> messages:
> make -f Makefile MAKEFILE=Makefile VARIANT=DEBUG
> make[1]: Entering directory
> `/home/sunshine/RTEMS/source/RTEMS-4.6.99.2/examples-4.6.99.2/hello_world_c'
> test -d o-debug || mkdir o-debug
> sparc-rtems-gcc --pipe -B/opt/rtems-4.6/sparc-rtems/leon2/lib/ -specs bsp_specs
> -qrtems  -qrtems_debug -g -Wall   -Wno-unused -qrtems_debug    -mcpu=cypress
> -msoft-float     -c   -o o-debug/test.o test.c
> -msoft-float         -o o-debug/hello.exe  o-debug/test.o
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-dpmem_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-event_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-msg_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-mp_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-part_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-signal_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-timer_g.rel
> /opt/rtems-4.6/sparc-rtems/leon2/lib/no-rtmon_g.rel
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-dpmem_g.rel: No such file
> or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-event_g.rel: No such file
> or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-msg_g.rel: No such file
> or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-mp_g.rel: No such file or
> directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-part_g.rel: No such file
> or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-signal_g.rel: No such
> file or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-timer_g.rel: No such file
> or directory
> sparc-rtems-gcc: /opt/rtems-4.6/sparc-rtems/leon2/lib/no-rtmon_g.rel: No such file
> or directory
> make[1]: *** [o-debug/hello.exe] Error 1
> make[1]: Leaving directory
> make: *** [debug] Error 2
> where can I find the files "no-dpmem_g.rel no-event_g.rel "etc. ?
The no-*_g.rel files are the debug binaries for rtems itself.  You're
trying to build a debug version of the hello_world_c program without the
  rtems debug binaries.  You need to build the debug version of rtems
with  'make RTEMS_BSP=leon2 VARIANT=debug'.
Cheers,
Keith
