MSDOS FS / MMC / rtems_io_register_name too many
Thomas Doerfler (nt)
Thomas.Doerfler at imd-systems.de
Fri Dec 30 20:27:33 UTC 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Pavel,
Pavel Pisa schrieb:
> Hello Thomas and others,
> I have one question related to RTEMS block devices.
> I observe, that rtems_io_register_name() reports "too many"
> in RTEMS-051009 checkout during my driver registration.
> Base filesystem holding /dev entry is full version of IMFS.
RTEMS objects have a static allocation scheme. The "too_manny" error
signals, that you cannot create a new object because it would exceed the
object storage. In your case, either the "maximum devices" (most
probable) or "maximum_drivers" or "number_of_device_drivers" entries
should be increased, see your "system.h" file and the "confdefs.h" which
is included there.
wkr,
Thomas.
> The message is not fatal, the device node is populated in fact correctly
> and subsequent operations works well. But it is not elegant to ignore
> this status report.
> Have you some idea, what could be cause of the problem?
> Thanks a successful year 2006 wishes
> Pavel Pisa
> Code in question
> #define MMCSD_DEVICE_NAME "/dev/mmcsd"
> rtems_status_code
> mmcsd_driver_init(void)
> int ret;
> rtems_status_code status;
> ret=mmcsd_init();
> if (ret != MMCSD_OK){
> ul_logerr("mmcsd_driver_init: low level initialization (mmcsd_init) failed\n");
> return RTEMS_NOT_DEFINED;
> status = rtems_io_register_driver(0,&mmcsd_driver_table,&mmcsd_major);
> if (status != RTEMS_SUCCESSFUL){
> ul_logerr("mmcsd_driver_init: rtems_io_register_driver %s\n",rtems_status_text(status));
> return status;
> status = rtems_io_register_name( MMCSD_DEVICE_NAME, mmcsd_major, 0);
> ul_logerr("mmcsd_driver_init: rtems_io_register_name %s\n",rtems_status_text(status));
> return status;
> return RTEMS_SUCCESSFUL;
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDtZgzwHyg4bDtfjQRApqrAJ9gksLJQs+XiEmjHQFZcfvHKWF3swCeM9GT
ujSgy8JJZxSFCzM5805YDvA=
=vbJ9
-----END PGP SIGNATURE-----
