[rtems-users] New MCF5282 BSP
D. Peter Siddons siddons at bnl.gov
Wed Feb 2 17:27:59 UTC 2005
Hi Eric,
    Do the binary rpms on the RTEMS web server work for this bsp? If so,
which ones are needed?
Pete.
Eric Norum wrote:
> Mike Bertosh wrote:
>> Hi all,
>> I am having trouble building rtems with the mcf5282 bsp that was
>> added a few days ago.
>> It seems that the m528x option doesn't exist and I was wondering what
>> needs to be done to fix this problem. I have already re-installed the
>> cross-compiler tool set and made sure that this directory has been
>> added to my PATH variable. Any help or suggestions would be greatly
>> appreciated. Thanks for your time.
>> -Mike Bertosh
> You need a newer compiler to build this BSP.  I'm using gcc-3.4.3.
