Passing Parameter(s) to tasks/threads
Aaron J. Grier aaron at frye.com
Fri Feb 11 19:41:22 UTC 2005
On Thu, Feb 10, 2005 at 07:42:42PM -0500, Smith, Gene wrote:
> I need to pass from 0 to 10 integer parameters to my tasks when they
> are started with rtems_task_start().
if sizeof(rtems_task_argument) == sizeof(int**) on your target, you can
use explicit casts to convert between the two.
another way to do would be to pass a message queue ID as an argument,
and then have the task read its parameters from that queue.
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
  "Note that many bands' backline amps produce levels exceeding OSHA
   standards for industrial facilities.  Yet this is considered normal
   working conditions for musicians.  That's showbiz." -- Scott Dorsey
