General Question: Saving Configurations
Ed Sutter esutter at lucent.com
Fri Feb 18 12:36:46 UTC 2005
Paul,
The file system in MicroMonitor's TFS would probably work
out well for this.  Generally speaking TFS is most easily
used by the application if MicroMonitor is used as the
boot monitor (if you're interested in this let me know).
Alternatively, I suppose TFS could be yanked out of MicroMonitor
and used as an alternative means of flash file storage in
RTEMS.
Ed
> Hi All,
> I am about to create an application in which I will be
> saving configuration details.
> The board I am using has flash memory on it, and currently
> I am thinking of just saving the configuration into
> a section of the flash memory.
> I was wondering whether it is worth using some sort of
> simple  file system,or if there is a more generic
> approach other people have taken.
> Thanks in advance
> Paul
