Error configuring RTEMS 4.7
Peter Dufault
dufault at hda.com
Fri Feb 18 13:25:53 UTC 2005
I'm trying to build the MVME5500 BSP in powerpc using 4.7, but I'm not
having much luck.
I'm using the same set of tools in the past:
autoconf259
autoheader259
autom4te259
automake19
aclocal19
gm4 is GNU m4 1.4.1
but gm4 core dumps with a SIG11 during the bootstrap phase:
Memory bounds violation detected (SIGSEGV). Either a stack overflow
occurred, or there is a bug in /usr/local/bin/gm4. Check for possible
infinite recursion.
autom4te259: /usr/local/bin/gm4 failed with exit status: 139
The system is:
FreeBSD shrimpy 4.11-RELEASE FreeBSD 4.11-RELEASE #4: Mon Feb 14
12:35:18 EST 2005 dufault at shrimpy:/usr/src/sys/compile/SHRIMPY i386
I've attached a shell script and its output. I've named them ".txt" to
get past the mail filter.
Peter Dufault
HD Associates, Inc.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050218/d5e58449/attachment.txt>
URL: <http://lists.rtems.org/pipermail/users/attachments/20050218/d5e58449/attachment-0001.txt>
