powerpc-rtems-4.7-gcc-4.0 patch commited
Sergei Organov osv at topconrd.ru
Fri Feb 18 13:28:47 UTC 2005
"Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com> writes:
> There is a PPC_INTERRUPTS_MAX which still remains to be addressed.
> Ralf.. I think the the MIPS defines that in libcpu as a variable used by the
> cpukit.
IMHO, it's time to define generic interface between cpukit and the rest
of RTEMS BSP that will ensure compile-time independence of cpukit, or at
least to document some guidelines. It seems that pre-multilib BSP
interface definitions don't address the issue as in fact every BSP is
now split between cpukit and the rest of libs and there is no definition
of the interface to be used on this split line. Does it sound
reasonable?
Sergei.
