powerpc-rtems-4.7-gcc-4.0 patch commited
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Feb 18 15:09:04 UTC 2005
Ralf Corsepius wrote:
> On Fri, 2005-02-18 at 06:24 -0600, Joel Sherrill  wrote:
>>>E.g. the m8260 would be superflous, if it could be removed from cpukit.
>>>The code it uses is _identical_ to the 603e, except of 1 define in
>>>cpukit.
>>OK. Are you referring to this code?
>>#if (defined(ppc403) || defined(mpc860) || defined(mpc821) ||
>>defined(mpc8260))
>>   uint32_t     serial_per_sec;         /* Serial clocks per second */
>>   boolean      serial_external_clock;
>>   boolean      serial_xon_xoff;
>>   boolean      serial_cts_rts;
>>   uint32_t     serial_rate;
>>   uint32_t     timer_average_overhead; /* Average overhead of timer in
>>ticks */
>>   uint32_t     timer_least_valid;      /* Least valid number from timer
>>   boolean      timer_internal_clock;   /* TRUE, when timer runs with
>>CPU clk */
>>#endif
>>#if (defined(mpc555) || defined(mpc860) || defined(mpc821) ||
>>defined(mpc8260))
>>   uint32_t     clock_speed;            /* Speed of CPU in Hz */
>>#endif
>>These are the HW configuration parameters required by  portions of
>>libcpu which are provided by the BSP.  How about another mechanical fix?
>>Two alternatives:
>>   + Define this as a structure that is provided by the BSP.
>>   + Like other portions of libcpu, assume that the BSP is providing
>>     a single global variable like "BSP_clock_speed" and change the
>>     code in libcpu to use it.
> Cf. what I wrote a couple of minutes ago.
> We need data abstraction, not defines.
I really didn't want a define.  I want the contents of this structure
defined in a set of .h's in libcpu.  Then autoconf picks the right
CPU-model specific version.
>>Can you point me to a specific ifdef to nibble on?
> At the moment ,the brute force fix would be to remove all these defines
> and to add these variables unconditionally.
That is what other drivers in libcpu have done.  If you use driver X
from libcpu, then you are obligated to provide certain intialized
variables to configure it.
--joel
