Unified PCI API
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Sun Feb 20 00:49:57 UTC 2005
Since there is so much discussion on another thread about the PowerPC
and IRQs, I think a comment I made on the PCI API was taken wrong.
I think the PCI API is independent of the Interrupt/Exception API
and PowerPC cleanup.
The current situation is that the PowerPC pci.h was used as a baseline
PCI API and the .h file defining 90+% of the API is now defined in
cpukit/include/rtems/pci.h. My current plan is to modify the x86 port
to follow this API except for a couple of warts in the current API which
I intend to fix.
+ the x86 PCI API includes a "PCI Bus initialize" function missing in
the cpukit pci.h
+ the "find device by ID" routine in the original PowerPC PCI API has
an ugly name.
+ the x86 has some "find device by XXX" alternatives which would be
nice to include in the cpukit pci.h
At this time, I am unifying the API and modifying all impacted code.
I will NOT alter any exception/interrupt/IRQ interface specifications
as part of this work. Also this is COMPLETELY independent of any
PowerPC movement or cleanup.
For those who care, the x86 PCI API uses a "signature u32" to identify
devices while the PowerPC/cpukit API uses a "bus, device" combination to
identify devices.
I am willing to listen to suggestions on the unified API but they better
be backed up by help. :)
joel at OARcorp.com On-Line Applications Research
