No rule to make target `new-exceptions/cpu.c'
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Feb 23 18:17:57 UTC 2005
Ralf Corsepius wrote:
> On Wed, 2005-02-23 at 11:59 -0500, Peter Dufault wrote:
>>I've gone through the configuration and build on Fedora 3 now as well
>>as FreeBSD.  When I try to build psim (or mvme5500, which is what I
>>eventually want to get to) on both systems it eventually stops with:
>>*** No rule to make target `new-exceptions/cpu.c', needed by
>>`new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o'.  Stop.
>>The configuration I'm using is:
>>../rtems4.7/configure
>>--target=powerpc-rtems
>>--enable-maintainer-mode
>>--prefix=/opt/rtems-4.7
>>--disable-posix
>>--disable-networking
>>--disable-cxx
>>--disable-multilib
>>and the behavior is the same whether I add "--enable-rtemsbsp=psim" or
>>leave it out and do make RTEMS_BSP=psim.
> As I already outlined on PM, some exception-related directories have
> been moved in CVS. Therefore the information you are providing is
> insufficent to be answered.
> Most probably you need to
> cvs up -dP
> ./bootstrap -c
> ./bootstrap
> Also, make sure to have the patch attached to PR 546 applied to your
> auto, and make sure to have /opt/rtems-4.7/bin at the beginning of your
> $PATH.
Why are you still using an automake that is a few verions old?
AFAIK neither 1.8.2 nor 1.9.2 required a patch.
>>Since there has been a lot of discussion of new-exceptions, can someone
>>verify that psim should build OK if I've got things configured
>>correctly?
> Yes, 100s of times.
Double, triple yes. :)
--joel
