No rule to make target `new-exceptions/cpu.c'
Ralf Corsepius ralf.corsepius at rtems.org
Thu Feb 24 03:03:43 UTC 2005
On Wed, 2005-02-23 at 12:17 -0600, Joel Sherrill  wrote:
> Ralf Corsepius wrote:
> Why are you still using an automake that is a few verions old?
> AFAIK neither 1.8.2 nor 1.9.2 required a patch.
ATM, rtems-cvs requires automake >= 1.9 with the patch attached to PR 546 applied.
I am using automake-1.9.5 + the patch.
A successor of the patch attached to PR546 is part of automake-cvs
trunk, the cvs branch automake-1.10 once shall be released from.
Don't be fooled by the name of the patch - It had been cut when
automake-1.8.1 was current, but it still applies and meanwhile is
required by many Makefiles in RTEMS.
[automake uses a similar branching scheme as GCC:
There exists a 1_9-branch from which current bug-fix releases are cut,
while trunk contains development versions.]
Ralf
