rtems_task_wake_after problem
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Feb 25 12:28:00 UTC 2005
Adam Piotrowski wrote:
> Hello
> I have little problem with rtems_task_wake_after(...) function.
> I wrote some driver for my device (nvram) but I need some delay function. I
> wanted use rtems_task_wake_after but this function hang my system for ever.
> It is something that I should know about this function? I used it in my
> programs and everything was OK, but in driver it faild.
You need to have the Clock driver configured.  See the ticker sample
application.  Sounds like you started with the hello world which doesn't
include it.
> Adam Piotrowski
> NAJLEPSZA NA SWIECIE...
> Sprawdz >> http://link.interia.pl/f185e <<
