Are PCI bridges automatically configured?
Peter Dufault
dufault at hda.com
Fri Feb 25 19:19:03 UTC 2005
Are PCI bridges automatically configured without any special code?
I changed the hardwired number of busses from 2 to BusCountPCI() in the
mvme5500 pcifinddevice.c, and now I am seeing the PCI bus on the other
side of the DEC 21150 bridge:
cexp_main>BSP_pciFindDevice(0x16d5,0x4d4d,0,pbus,pdev,pfun)
BSP_pciFindDevice: found 0x643011AB at 0/0/0
BSP_pciFindDevice: found 0x643011AB at 0/0/1
BSP_pciFindDevice: found 0x643011AB at 0/0/2
BSP_pciFindDevice: found 0x643011AB at 0/0/3
BSP_pciFindDevice: found 0x643011AB at 0/0/4
BSP_pciFindDevice: found 0x643011AB at 0/0/5
BSP_pciFindDevice: found 0x643011AB at 0/0/6
BSP_pciFindDevice: found 0x643011AB at 0/0/7
BSP_pciFindDevice: found 0x445716D5 at 0/6/0
BSP_pciFindDevice: found 0x00263388 at 0/10/0
BSP_pciFindDevice: found 0x000010E3 at 1/0/0
BSP_pciFindDevice: found 0x00221011 at 1/4/0
BSP_pciFindDevice: found 0x4D4D16D5 at 2/2/0
0x00000000 (0)
cexp_main>
so that last entry is my Acromag PMC341 card.
So now I guess I follow what I see in the libchip/network drivers for
setting things up using "pci_write_config_foo"? I don't need any DEC
21150 specific code anywhere? Do the "pci_write_config_word" calls
allocate resources?
Any "heads up" appreciated, I'm just getting started on this part.
Peter
Peter Dufault
HD Associates, Inc.
