[rtems-users] C++ Virtual Functions
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Feb 1 21:07:22 UTC 2005
gregory.menke at gsfc.nasa.gov wrote:
> Smith, Gene writes:
> > I am having some problems running code containing C++ virtual functions in
> > rtems. When the code tries to branch to a virtual function address using
> > "bctrl" instruction, the address (in ctr) is way out of range and results in
> > a machine check exception.
> > Is there anything I need to do special in rtems for virtual functions to
> > work? Is anyone using virtual functions, pure or impure, in rtems? I am
> > still using rtems 4.6.1 and my ppc40x-derived bsp.
> > Tks,
> > -gene
> This is generally caused by problem with the linkscript where the
> various tables are set up incorrectly. The motorola_shared bsp link
> script works, so you might compare them for discrepancies. It might
> also be related to your gcc- but I'd check the linkscript first.
psim on the CVS head and post 4.6.2 on the 4.6 branch is also supposed
to work for C++.
Look at the bsp_specs as well for crt*.
If you have a simple example, you want tried on another BSP, post it.
joel at OARcorp.com On-Line Applications Research
