[rtems-users] New MCF5282 BSP
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Wed Feb 2 18:10:10 UTC 2005
D. Peter Siddons wrote:
> Hi Eric,
> Do the binary rpms on the RTEMS web server work for this bsp? If so,
> which ones are needed?
It is on the CVS trunk so the RPMs for "m68k-rtems4.7" should work fine.
I can't confirm that at the moment as I have been testing gcc 4.x
snapshots on the tree.
--joel
> Pete.
> Eric Norum wrote:
>> Mike Bertosh wrote:
>>> Hi all,
>>> I am having trouble building rtems with the mcf5282 bsp that was
>>> added a few days ago.
>>> It seems that the m528x option doesn't exist and I was wondering what
>>> needs to be done to fix this problem. I have already re-installed the
>>> cross-compiler tool set and made sure that this directory has been
>>> added to my PATH variable. Any help or suggestions would be greatly
>>> appreciated. Thanks for your time.
>>> -Mike Bertosh
>> You need a newer compiler to build this BSP. I'm using gcc-3.4.3.
joel at OARcorp.com On-Line Applications Research
