[rtems-users] microwindows 0.90-rtems 4.7-pc386 - executing demo problems
Mark Mussetter
mark at link-comm.com
Mon Feb 7 16:34:07 UTC 2005
We got that error when we were getting started as well. Turned out that we
needed to actually create and install a framebuffer driver
(/dev/fb0). Using Rosimildo da Silva's patch for rtems as a starting
point, this is what we had to do:
1) In rtemscfg.h, changed the
CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS define to allow more devices.
2) Added MY_FRAMEBUFFER_DRIVER_TABLE_ENTRY to the Device_drivers table
3) Defined MY_FRAMEBUFFER_DRIVER_TABLE_ENTRY in framebuffer_driver.h
4) Wrote functions FB_Initialize, FB_Open, FB_Close, and FB_Control.
Everything else is pretty hardware specific but this should get you started.
Hope this helps,
Mark
/* In rtemscfg.h (Values that override settings in confdefs.h) */
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10 /* overriding confdefs
value of 3, so can install our devices including /dev/fb0 */
/* List of device drivers loaded by RTEMS at boot time */
rtems_driver_address_table Device_drivers[] =
CONSOLE_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
/* this can be a bit tricky if you are using a serial mouse,
make sure that you do not install and serial driver that
uses the same port !!!!
#if 0
TTY2_DRIVER_TABLE_ENTRY,
#if PS2_MOUSE
PAUX_DRIVER_TABLE_ENTRY,
#else
* Make sure that you have selected the COM port and the
* mouse type in ( c/src/lib/libbsp/i386/pc386/console/serial_mouse.h ).
SERIAL_MOUSE_DRIVER_TABLE_ENTRY,
#endif
/* Standard VGA driver */
FBVGA_DRIVER_TABLE_ENTRY,
#else
{NULL,NULL,NULL,NULL,NULL,NULL},
#endif
MY_FRAMEBUFFER_DRIVER_TABLE_ENTRY,
MY_ADS_DRIVER_TABLE_ENTRY,
PTY_DRIVER_TABLE_ENTRY
#include <confdefs.h>
/*In framebuffer.h */
rtems_device_driver FB_Open( rtems_device_major_number major,
rtems_device_minor_number minor,
void *args );
rtems_device_driver FB_Close( rtems_device_major_number major,
void *args );
rtems_device_driver FB_Control( rtems_device_major_number major,
void *args );
rtems_device_driver FB_Initialize( rtems_device_major_number major,
void *args );
//When using the following driver setup, we don't need a read or write
function since the subdriver "fblinx.c" handles the pixels directly
#define MY_FRAMEBUFFER_DRIVER_TABLE_ENTRY \
{ FB_Initialize, FB_Open, FB_Close, NULL, NULL, FB_Control }
At 08:20 AM 2/5/2005, you wrote:
>Hello all,
>I've compiled microwindows demo for pc386 bsp.
>Trying to run wdemo on real pc and bochs too, I found problem in getting
>access to /dev/fb0.
>In microwindows/src/scr_rtems.c :
>static PSD
>fb_open(PSD psd)
> char * env;
> int type, visual;
> int tty;
> PSUBDRIVER subdriver;
> struct fb_screeninfo fb_info;
> assert(status < 2);
> /* locate and open framebuffer, get info*/
> if(!(env = getenv("FRAMEBUFFER")))
> env = "/dev/fb0";
> fb = open( env, O_RDWR);
> if(fb < 0) {
> EPRINTF("Error opening %s: %m\n", env);
> return NULL;
>Call to open() always returns -1.
>Anyone may help?
>Thanks.
>Luca
Mark Mussetter
Link Communications, Inc.
1035 Cerise Rd
Billings, MT 59101-7378
phone: (406) 245-5002 ext 105
Fax: (406) 245-4889
WWW: http://www.link-comm.com
MailTo:mark at link-comm.com
