powerpc altivec support
Till Straumann
strauman at slac.stanford.edu
Wed Feb 9 04:44:21 UTC 2005
Ralf Corsepius wrote:
>On Tue, 2005-02-08 at 15:52 -0800, Till Straumann wrote:
>>Hi.
>>I'm looking into ALTIVEC support for RTEMS along the lines of
>>lazy FP context switching. However, I'd like to hide this from
>>SCORE code for obvious reasons. OTOH, it seems also ugly
>>to switch the vector registers as a side effect of CPU_Context_switch().
>>Any suggestions?
>>Ralf: what needs to be done to get an altivec enabled toolchain and
>>newlib for the CPU variants that support it?
>Basically, by adding appropriate multilib variants to GCC.
>In general have to prove that such a multilib variant actually makes
>sense (gives a measurable improvement in performance)
>and can not be avoided by other means.
As far as I could see, lack of an altivec variant has the following
implications:
- libgcc doesn't use altivec --> only a possible stack misalignment
- newlibc setjmp/longjmp would not save/restore the altivec registers
-> BAD
- newlibc vfprintf() would not support vector formats -> undesirable
==> if we added altivec support to RTEMS [very desirable for
number-crunching
applications], we certainly need a newlibc with altivec support.
The good news is, however, that the newlibc code (essentially
setjmp/longjmp)
which needs a small __rtems__ patch anyways could perform a
quick run-time
check for altivec, i.e., altivec could essentially be enabled
for any ppc variant
(or at least 7400++).
>However, due to the number of multilib variants being used by the
>powerpc, convincing me to add another one to powerpc-rtems-gcc will be
>extraordinarily tough.
>>BTW: I see in gcc/config/rs-6000/t-rtems (gcc-3.2.3 / rtems-4.6) that
>> "no-eabi" is passed to all PPC variants (MULTILIB_EXTRA_OPTS)
>> -- this might be out of sync, as EABI is the default PPC abi for
>> RTEMS
>Is it? That's news to me, but ...
>cf. http://www.rtems.org/cgi-bin/gnatsweb.pl?cmd=view&pr=195
>... nobody ever has been able to sort this out.
Looks like chicken + egg.
BTW: mno-eabi probably doesn't really have a great impact as this
effectively only
changes the stack alignment. The really interesting thing
could be
enabling both 'meabi' and 'msdata=eabi'. This would improve
both, space
*and* speed efficiency.
OTOH, I totally agree that there are too many possible and useful variants.
I'd propose to discuss doing away with some of the 604 compatible variants
- probably, just one of them would be enough, e.g.:
a) 604 with no altivec
b) 7400 with altivec
--> AFAIK, a) can be run on anything from 604..7400 (assume gcc/newlib needs
only the UEA)
--> applications with need for altivec can use b)
Also, I don't see the benefits of a soft-float variant for all of the
604++ machines
(maybe that applies to pre-604 also, I just know 604++ best).
OTOH, having a few 'msdata=eabi meabi' variants would be useful.
Baseline: IMO, the number of pre-built variants should be cleaned up AND
a HOWTO would be desirable for users wanting to build
tailored toolchains.
An embedded board with low memory might significantly
benefit
from meabi/msdata=eabi and a high end application
might need
cpu=7450 maltivec mabi=altivec. The user should be
assisted
generating a tailored toolkit
>> [score/cpu/powerpc/rtems/score/ppc.h says:
>[This file is obsolete, score/cpu/powerpc/rtems/score/powerpc.h has
>replaced it.]
>>* Default to the EABI used by current GNU tools
>>#ifndef PPC_ABI
>>#define PPC_ABI PPC_ABI_EABI
>>#endif
>> and I believe nobody ever defines this to something else.
>:-) Cf. http://www.rtems.org/cgi-bin/gnatsweb.pl?cmd=view&pr=195
>Ralf
