RFC: Removing OLD_EXCEPTIONS powerpc multilib variants
Sergei Organov osv at topconrd.ru
Wed Feb 9 11:09:36 UTC 2005
Ralf Corsepius <ralf.corsepius at rtems.org> writes:
> If you should maintain/use an old exception-based BSP not using one of
> these 2 variants, which is not in RTEMS main source-tree speak up NOW or
> it will be too late :-)
I do use my own old exception-based BSP but I in fact don't care about
multilib variants removal. Well, unless you are going to remove old
exception processing support entirely that obviously is not the case.
Sergei.
