PowerPC question
Smith, Gene gene.smith at siemens.com
Wed Feb 9 14:57:29 UTC 2005
Leon Pollak wrote, On 2/9/2005 3:43 AM:
> On Tuesday 08 February 2005 22:00, Smith, Gene wrote:
>>This is not really directly related to rtems but since there seems to
>>be a lot of powerpc users here I thought I would ask.
>>My timer interrupt is implemented using the PIT at vector offset
>>0x1000. Should setting the MSR register to 0x21000 (EE bit off)
>>disable the timer interrupt? This is for ppc405gpr. For some reason I
>>still seem to see the timer interrupt when MSR is set to this or even
>>when set to 0.
>>Thanks,
>>-gene
> Hello,
> 	I remember to have the similar problem some (a lot of) time ago. I
> think you have fallen into the same catch...:-)
> 	I tried to switch the interrupts OFF by setting the MSR[EE} to zero in
> a task. The trick is that task switch causes the MSR value to be
> restored to the value it was in other tasks. You may find the
> discussion of this on the mail list about 2-3 years ago...
> 	I still think that this is not 100% correct way, but, seems to me Ralf,
> insisted that this is correct. I solved my problem by masking
> undesirable interrupts in corresponding peripherals.
> 	Hope this helps...
Hello Leon,
I went back and found the MSR discussions you mention. I think it is
saying that if I disable the MSR's EE bit while stepping through a given
task it prevents me from stepping into the timer interrupt (which
happens if I don't set EE to 0). However, if I "continue" in gdb and a
task switch occurs, MSR will be restored in the switched-to task with EE
probably on and the timer interrupt then occurs. That is probably what I
am seeing. I have often set EE off and think that is a permanent change
and then see it come back on by itself (after continuing to a bp). I
guess to globally (in all  tasks) turn off the timer interrupt I need to
turn off the PIT timer itself, not just MSR's EE bit while in a task.
Thanks,
-gene
