Device Driver Skeleton?
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Feb 14 22:50:24 UTC 2005
Angelo Fraietta wrote:
> angelo wrote:
>> On Fri Feb 11 10:00:51 PST 2005, =?iso-8859-1?Q?Alex?= <kbyte at iol.pt>
>> wrote:
>>> Good Morning Dr Fraietta,
> Not Dr yet.
>>> At some days ago, I had a doubt concerning writing my first device
>>> driver and you said to me to send you an email on the 10th feb. So
>>> here I am... Could you help me, please?
> OK
>>> I already study the console and serial drivers in the rtems
>>> distribution and appart from the skeletton of a generic rtems device
>>> driver, why do we have to define always a macro like this:
>>> #define CONSOLE_DRIVER_TABLE_ENTRY \
>>> { console_initialize, console_open, console_close, \
>>> console_read, console_write, console_control }
So the application which builds the device driver table doesn't have
to know the details of a particular driver. Maybe you have a write only
console and don't support read. This is really an application
configuration convenience.
>>> Who invoke those functions members, and in what circunstancies?
> This is my understanding of what happens. Hopefully, someone will
> correct me if I am wrong.
> The initisalise function,
> console_initialize in this case, is called when the device drivers are
> initialised.
> The Open is when you a file open on this device, the close when you do a
> file close, the read when do do a read from the file, the write, when
> you do a write to the file, and I am not sure what the control does.
Correct. device driver initialization in this case is done before
multtaskign is started. Do not block in a driver initialization of you
will hang the system.
> I have only implemented the initialise because I write to my device
> direct. I have not implemented a read, or write -- I don't treat my
> device like a file. I suppose that that is what you have to decide
> first--whether you want to treat your device like a file or whether you
> want to write directly from your application
Correct. The other calls help plug into the filesystem framework and
let you access /dev/console or /dev/comm0 or /dev/hd0 just like you
would be able to on a POSIX system.
>>> Which are the steps to put to work a device driver made by us, or,
>>> using the hello world sample how can we put a device driver to work?
> I would have a look at an example that uses a COMM port (TTYS1) if you
> want to open and close your device like a file.
joel at OARcorp.com On-Line Applications Research
